ULCS Ball Adapter for Ikelite DS200
Started by Wahoo ·
  1. For anyone using Ultralight arms and Ikelite strobes, how do you attach the ULCS ball adapter to the strobe? I have an Ikelite DS200 and the ULCS AD-200 ball adapter that has a flat washer (next to strobe) and a lock washer (next to the adapter). The problem is the lock washer cuts the o-ring on the bottom of the adapter. After I used this set-up once the o-ring was cut clear through. Do you forget the o-ring or the lock washer?
  2. I use them both....they don't ever come off, so if the o-ring is damaged....oh well :):(
    Karl
  3. I don't use any washers, and never had a problem. The pressure on the O-ring keeps everything together.
