Addition to current system
Started by Jay-11 ·
  1. I'm currently using the following system:
    S2 Pro in a Subal housing
    20mm lens - 6" dome port
    105mm lens - 105 port
    2 Inon strobes
    I'm looking at adding another lens to this system and was wanting to get some recommendations. I have heard that the 12-24 lens would be a good addition but was also wondering about the 60mm Macro? If I added either of these lenses to my system could I use the same ports or would I need to add new ones?
  2. I would highly recommend that you look at the 15mm Sigma fisheye. You can use it w/ the 6" port.
  3. HI,
    I use both the 12/24 nikon & the 60mm micro. I find that the 60mm is
    easier to use than the 105mm & as the port is shorter than the 105mm.
    The 12/24 is a wonderful lens & it can focus down to 100mm, so you can
    get very very close & reduce the water colunm to produce better images.
    As far as ports go I use a 35mm extender with my wideport also I have
    a zoom gear fitted. This with my SeaCam housing so I can not comment
    on a Subal. But both lens are great & would be great additions.
    Andy :lol::rolleyes::lol::huh:
