YS30 II TTL Duo
Started by famorim ·
YS30 II TTL Duo
  1. Hi folks
    I'm looking for a Mathias sensor compatible strobes for Macros. I'm thinking about the S&S YS30 II TTL due the weight and size for travels. Could anyone tell me if this strobe has power enough to light a macro scene for 100mm Macro + TC 2x at f/16 and 1/125 ?
    Regards
    Fabio
  2. Hi,
    I have this strobe. It is supposed to be 30 watt-seconds but is probably less. Ikelite DS50's are 50 watt-seconds, and they are sufficient for the shots you have specified, but only if pointed correctly and pushed out to the front of the port.
  3. James,
    thanks for the answer.. I'll try to get a trial with this strobes. I'm also saw the ike strobes, but it may be a problem for who lives in Brazil if the strobes get any problem due the burocracy of customs. S&S and Inon both has repair centers down here.
    Thank you.
    Fabio Amorim
