Subal dome port shade collar
Started by maelstrom ·
  • 9Posts
  • 9Replies
  1. The plastic shade/ collar on my Subal dome port broke mysteriously on a boat last week. I obtained a replacement, but it is horribly tight, and I can't get it on. I need it for a trip next week, so don't have time to send it in. Any suggestions?
    Hal
  2. Try warming it up with a hairdryer before pushing it on !
    I have seen a bunch of Subals with broken lenses shades recently, I recall hearing that the reason had been put down to a change in materials.
    Has anyone else had this problem ?
  3. I have knocked mine off a couple of times (not underwater) but it has always pushed back on!
  4. Run it under hot water-
  5. Run it under hot water-
    that's the solution...
  6. Thank you all. I will try it.
    Hal
  7. Is there not a little retaining grub-screw? I naturally broke mine (in April) and, surprise surprise, I am using a borrowed one while I wait for a new one to arrive! I had to saw off the grub-screw (electrolysis between steel and aluminium).
    Pity I've progressed to a different camera and housing since then.
    Edited by John Bantin
  8. It worked.
    Hal
  9. I also created a post about this subject.
    Could you please check it and tell me what you think about tha "marks" I talk about in my dome-port ?
    Best regards,
    Benoît
