Inon Strobes
Started by okuma ·
Inon Strobes
  1. For those of you shooting Inon 240 ( or 220) strobes, do you believe that they have adequate power to support Nilon 10 mm or 16 mm fish eye lens on nikon digital cameras?
    Thanks in advance!
  2. I'm quite happy with my Z-240's
    it depends on what you want to light i suppose, but using x2 i have not had problem at all.
    regards
    Craig
  3. I'm quite happy with my Z-240's
    regards
    Craig
    I usually shoot my 12-24, plenty of light. I borrowed my friend's 10.5 and there was plenty of light.
  4. I confirm that you should be OK with these strobes with either of the fisheye lenses...
  5. I've had my two Z220s for about 2 years and they have been terrific. No problem lighting a 10.5 in lightish water. I'm not so sure about the deeper, darker bits.
    Has anyone found that getting the strobes to start charging can be a bit of a challenge if they havn't been used for a while? I keep wondering if its maybe slightly dirty/greasy contacts- but I can't pin down the cause. It usually takes me several attempts and changing/polishing batteries to get the strobes up and running - then they are as good as gold.
  6. In my experience over 3 years of using Z-220s's with a 1.6x, 1.3x and full frame camera, I've come to find that although power can be an issue sometimes, using the Inons on a full-frame camera starts giving coverage issues sometimes.
    By that I mean that with a fisheye 180 deg. lens on a full frame camera, I find myself lighting two sides of a wide angle shot with significant falloff in the middle of the frame.
    I have considered getting a 3rd Inon Z220/240 to cover the middle of the frame, which actually Ryan Canon of Reefphoto does on occasion. He does recommend it - so that is one possible solution if you run into coverage problems with a Fisheye.
