ikelite iTTL with D70 and DS125 - settings
Started by clairegoodwin ·
  1. Just got my ikelite Nikon D70 housing converted to iTTL circuitry. I had been getting good results on manual but now with the iTTL all the pictures are very over exposed - I have tried using the EV compensation button but the results are still overexposed when the maximum compensation is used.
    I'm using a 60mm lense and have the camera set to manual (f32, shutter speed 125). I have the strobe turned to the TTL setting on the dial and set to TTL inside the housing. The strobe works on the manual 1/8, 1/4 and 1/2 power settings but not on full (it fires but out of synch with th shutter so the picture is not lit) - I see from an earlier post that this is something to do with recycling times from the pre-flash.
    Ikelite hadn't supplied instructions on using the TTL and I can't find anything on their website. I have emailed them for suggestions but thought I should try here too. I'm sure it is something very basic that I am doing wrong with the camera settings but have no idea what it is! Is it right that I should not use the maunal settings on the strobe now but change to manual by pressing two buttons on the housing simultaneously?
    I got a new synch cord in case this was the problem but no luck there. The cord and strobe are both iTTL compatible.
    Thanks for your help,
    Claire
  2. Hi Claire,
    I have the same rig as you. I was on the phone with Ikelite a couple days ago and they did mention that if your DS-125 has a serial number below 5,000 then it will require a circuitry update to get optimum iTTL performance. You can find the serial number next to where you plug in the charger.
    Hope this helps.
    -Chris
