I am a total newbie to underwater photography and this might have been covered already but just in case it hasn’t I will pass this along.
If you have a 20d with a Sigma 14mm 2.8 in an Ikelite housing with the 8â€dome port you need to attach the port to the housing before putting the camera in the housing, on mine when I rotate the port to put it on the housing the edge of the lens put a nice scratch on the inside of the housing but it lines up with the edge of the lens so I am hoping it wont be noticeable in images.
I also had a few things I am curious about any advice would be greatly appreciated.
First is Balance, I haven’t been the water with the rig yet but it seems very off balanced with the strobe hanging out front, does this improve in the water or is a counter weight needed.
Second is the 8†dome port. I bought the Ikelite Pelican case and don’t see an apparent way to store the port in the case other than flat and that takes up a lot of room.
Third is transporting the housing with the Camera in it. I know the manual says not to but I don’t see how it could cause a problem as the fit is so snug I don’t think it would move around in the housing.
Thanks, Wayfarer/Pete
