Christmas in St. Croix
Started by Kasey ·
  1. I love to photograph these guys! Drop the hammer!!!
  2. Nice shot! I find the bright yellow areas in the background distracting, however. A little work in Photoshop to tune it down a bit?
    Regards,
  3. Example attached - I hope.
    Regards,
  4. Nothing like "too much" depth of field eh? :-) I have the same comment as Don regarding the background. But heck, sometimes you just can't get down enough without bashing the coral.
  5. Don and James -
    That is a really useful point. Shooting super tiny critters, it can be really challenging to get the subject perfectly in focus. Therefore, I always set the aperture to min to maximize DOF. I will experiment with larger apertures for subjects like these, which are common enough that I need not fear missing the opportunity.
    As far as getting low enough, I was shooting almost level with the subject but the coral protruded up and above the worm as it often does.
    Thanks for the constuctive critique.
    Don - what method did you use to work on the background?
  6. Don - what method did you use to work on the background?
    Kasey -
    I used the "magic wand" tool in PS7 set to "noncontiguous" to select the lightest areas. I then feathered and copied the selection to its own layer and used the Image/Adjustments/Brightness&Contrast to reduce the brightness of the copied layer by 50% and increase the contrast 10%. I then merged the layers.
    Regards,
