Strobe problem and recycle time
Started by motionsync ·
  1. I am right now in Dahab and for the first time i use my strobes very much day in day out..
    The think that i have discover is that if i use the strobes some times the recycle time get longer and longer..
    Now maybe this is normal becaoce both my strobes , Hartenberger 250 & Subtronic Gamma are not new ones and the batteries are not as now.
    But is it normal after 100 shots that i have this problem?
    Lambis
  2. Hi Lambis,
    If your problem develops after you've taken 100 shots at full power with your strobes while using the pilot light, then it's probably normal. If the 100 shots were not at full power, or you didn't use the pilot light, then the battery packs are likely too old and should be replaced...
