Teleconverter use with Nikkor 60?
Started by cdoyal ·
  1. I use a 60 on my D200 and Fuji S2 and love it. Has anyone used a teleconverter with one? I'm considering using this option until my bank account gets replenished and I can buy a 105 macro.
    Any thoughts would be appreciated. Thanks.
    Edited by cdoyal
  2. I use a 60 on my D200 and Fuji S2 and love it. Has anyone used a teleconverter with one? I'm considering using this option until my bank account gets replenished and I can buy a 105 macro.
    On my last trip to N. Sulawesi I used my 60mm with a Kenko 2X TC on several dives. Here are acouple of the shots I got.
    Dave
  3. I regularly use the 60mm with a 2x TC, either to get higher magnification or greater working distance. The setup works well, but it does slow down the AF a fair bit. Also, shooting in less than optimal light becomes rather difficult.
  4. I regularly use the 60mm with a 2x TC, either to get higher magnification or greater working distance. The setup works well, but it does slow down the AF a fair bit. Also, shooting in less than optimal light becomes rather difficult.
    Is depth of field affected at all or is it about the same as you would expect from a 120mm macro?
  5. It's hard to judge, as depth of field is pretty small for high magnification shots in any case (with or witout TC). In theory, I suppose it is. Here's a quick sample of what you can expect. The eyes are sharp, and that's all you need :)
  6. Another question regarding this issue: Whats Ikelite's ports can be use with the 60 MM and the kenko X2 & X3 teleconverters?
    According to the specs:
    Nikon 60 mm length = 2.9"
    Kenko X2 length = 1.7"
    Kenko X3 length = 2.6"
    60 mm + X2 = 4.6'', Ike's port #5505.45 or #5506.5
    60 mm + X3 = 5.5'', Ike's port #5505.5 or #5506.5
    All this numbers are from B&H and Ikelite sites and good in theory, anyone can confirm of decline it?
  7. See my post in classifieds. I am selling everything you need for a great super macro system. I just upgraded to the AFS VR 105, so I need to replace all this stuff. Lucky me!
