Experimenting with Heinrich TTL and Nikon D200
Started by NWDiver ·
  1. Tomorrow will be the 1st trip out with the D200, Aquatica, Inon 2xD2000w/s and Heinrich’s TTL board.
    Going out with settings of:
    D200 Settings= Flash on Manual, Camera on Manual, SS@250 (max), ISO 100, WB Cloudy
    Inon/s Settings= Left dial at “STTL†and Right Dial at the 9 o’clock “ttl†position
    So what am I missing and what settings should I try?
  2. I don't think that there is one setting that'll do it all... For shutter and diafragm setting you should experiment a lot and there are many photographers that can explain you this if you can't figure it out yourself.
    I use both my Z240's in the manual+TTL mode with HW-converter. You set both strobes in M position and you have to push and lock the TTL button for this (the TTL will serve as an overexposure security to some extend). With the upper right knob i decide which strobe has the most output.
    enjoy your trip! Udo
  3. Good luck in mastering the "Heinrich" maneuvers.
    Frogfish
