HVX-200 Scene File Settings
Started by eyebound ·
  1. Any recommendations for HVX-200 Scene File settings using HD formats in a tropical environment?
    cheers
    Edited by eyebound
  2. What kind of shooting? Lights? Filter? Reef scene?
    For shallow bright scenes, I suggest CINE D.
    Knee : Med
    Detail: +5
    V Detail: +2
    NR: -1
    Chroma Level/Phase: +1
    Auto Iris: -1 (if you don't shoot manual that is)
    Gamma Cine V
    Matrix: enriched
    Zebra 90-95%
    Mode: 30PN
    Shutter is 60 or 120 depending on what I want to shoot.
    That's my normal mode but I keep different scenes for what I anticipate the conditions will be. If your housing doesn't have access then, just experiment yourself.
  3. Thanks Dru!
    I am headed to Roatan next week for the first time. I am using a Gates housing with an external monitor and HID's and the HVX for the first time UW. The housing allows for scene file changes so I was going to load it with a few settings to try.
    I also was curious if there was any use in trying to preset different COLOR TEMP values. I am unsure if the monitor will acurately reflect the recorded colors.
    I will have five days to fill my harddrives!
  4. Eyebound
    Per your PM, I use 1/120 shutter speed or higher when I shoot 60fps on a fast moving subject. The ability to freeze the frame allows for better slow motion in post. Watch out though... too high speed and you get a strobe like effect.
    Are you using a Firestore or just P2 cards? If P2, it's much better to shoot in native mode.
    Unless you know what depth you'll be at at all times, WB color temp will be useless.
    Edited by scubadru
  5. Eyebound
    Dru,
    Good point regarding fast moving objects.
    I will be shooting to 8GB P2's with the housing controls to switch to tape as I use up my 16+ minutes of P2 time.
    My intent is to transfer all the footage to D5 once home for archival. With this in mind, would UW recordings benefit from 1080i as opposed to 720p despite the native options in 720?
    My idea for white balance was perhaps to load each Scene File setting (F1-F6) with a different Color Temp value and stepping thru them as depth increases based on what the ext monitor was showing. This would assume that I am seeing accurately the color that is being recorded. I am unsure as to how the color of external monitor will look to me with ambient light and a foot of sea water between the screen and my mask.
    Of course I could just manually WB every few meters like everyone else!
  6. 8GB x2 will give you about 30 mins of 30PN. Just watch out with the variable frame rate feature. You can roll over 2x 8GB cards in 15 mins. Makes for great slomo but you limit recording time.
    The HVX is a 960x540 CCD sensor, using pixel shift to get 1080. Thus the resolution of 720P is better than 1080i from this camera.
    As for WB, Color shifts every 1-1.5m, ie the red,yellow orange bandwidth is absorbed more. And you only have 4 scene files. Doesn't make a lot of sense to preset WB on the camera unless you know what depth you'll be at.
  7. As for WB, Color shifts every 1-1.5m, ie the red,yellow orange bandwidth is absorbed more. And you only have 4 scene files. Doesn't make a lot of sense to preset WB on the camera unless you know what depth you'll be at.
    ...Tru dat, Dru, Tru dat
    Thanks!
