Experimenting w/Heinrich TTL, D200, Inon D2000W
Started by NWDiver ·
  1. Played with the Heinrich TTL in macro and WA situations. Nothing scientific and if anyone has ideas of ways to test just let me know. Equip: D200, Aquatica, Inon D2000ws x 2, Nikon 6mm lens and 12-24mm lens.
    General impression:
    Macro: TTL worked fairly well with manual setting and strobes set "eTTL" power dial set to "2.8/B". You can change SS or Ap and the strobes seem to compensate. If you use a Ap Priority it seems to set the SS to 1/15 as a default.
    WA: Again shot mainly Manual, leaving camera settings stactic and adjusting strobe output. Seems best results were with the Power Dial set to "B/2.8". At times increasing the power 4-5 stops did not make a huge difference in photos.
    Photo 1: SS125, f.20, ISO100, Manual
    Photo 2: SS60, f.4, ISO100, Manual
    Photo 3: SS15, f.9, ISO100 Ap Priority
    Photo 4: SS125, f10, ISO100, AP Priority
    Photo 5: SS/15, f14, ISO 100, AP Priority
    Photo 6: SS/60, f4, ISO100, Manual
    Photo 7: SS/50, f5.6, ISO100, Manual
    Photo 8: SS/50, f5.6, ISO100, Manual
    With the WA viz was about 20-30feet and the flash did a fairly good job of not increasing backscatter. One problem with WA: trying to shoot two Ling Cods, the light was ok used the internal Inon focus lights but everytime the photo just came out black. Turn 10 degrees put a white anem in the focus spot and get a good shot. Move back to the dark brown Ling Cod and again nothing.
    Edited by NWDiver
  2. Hi NWdiver,
    I did my first picts with Mathias's TTL converter yesterday and I'm happy with the results. I used it on my EOS5D (custom picture styles) + Canon EF 100mm f/2.8 Macro + Tamrom PRO 2x TC + double S&S YS120 strobes.
    The images was converted to JPG using Canon DPP and resized to 800x533(96dpi) using Adobe Photoshop CS2. I think the results was good for my eyes, I expended a little time adjusting the flash compensation and now using +1 on TTL converter.
    More picts can be found at: http://www.pbase.com/famorim/laje102006
    Regards. Fabio
    Edited by famorim
