Photoshop question
Started by PRC ·
Photoshop question
  1. Anyone know where the default setup for the smart sharpen filter is stored in CS2 ?
    It is a minor annoyance but somehow I have managed to alter the default on my machine to some ridiculous amount of sharpening - every time I use the filter I darn near have a heart attack when the default setting is applied.
    I have tried renaming the default setup and saving a new default setup from within the filter but it seems to ignore that - so I am now looking to delete or hack it.
    Paul C
  2. wierd. Mine usually just pops up a window with the settings when I hit control F. Then I can select the level of sharpening from there. It defaults automatically to the last setting I chose.
  3. Thanks Dave and Giles,
    Problem turned out to be my sort of error.
    Dave's reply put me on to it - I tried ctrl F but that accelerator was not assigned on my system, so I went in via the menu and found that the settings were the last that I used.
    The issue was that I seldom go in via the menu system - I had created an action which did the sharpening, the action was hard wiring the amount of sharpening which I had not anticipated.
    So now I will go fix the action.
    Thanks again,
    Paul C
