Ultra-Violet dive light/spotting lamps?
Started by GrtDay ·
  1. I recently came across a drop-in UV 18 LED-replacement module designed for the Mag-Lite which happens fit a Toshiba dive light I have.
    This may be a truly crazy idea, but what if I were to use this UV lamp as a spotting lamp (it's relatively bright at 2') in addition to my dual DS-125's and D200.
    I've never seen UV light underwater but can only imagine what it would do to some of the colors.
    Maybe I need to reload by bong but I thought this would be a pretty cool scenario. B)
    Expert- I await your input!
  2. just thinking out loud....
    i'm not sure if the camera sensors would be able to recognize the UV wavelengths. It may be beyond the visible range and thus the camera won't be able to lock or focus into what is essentially "dark" to the camera.
    On the other hand, if you are able to put a filter to see the UV wavelengths, this could be a fun creative way of doing night photography. You would be able to see the phosphoresence of the coral, fish.... hmmmm....
    this could be interesting...
    What wavelength is your lamp putting out?
  3. UV lights can be used to bring out the natural fluorescence of marine creatures. A company (NightSea) even developped dive lights and filters specifically for this purpose. There was an article in Asian Geographic on this topic a year or so ago.
  4. What Matt says, a UV light source is just an excitation source for the natural fluorescence in the subject. The fluorescence that we see is the visible spectrum part. If we can see it, so can our cameras. Having said that, the intensity is often low and the colours rendered by the camera will often be different to what we see, due to the camera's spectral response not being the same as ours.
    That low intensity precludes the use of strobes, as they will wash out any fluorescence. In fact most strobes put out a large amount of UV anyway, which alters the colours of some corals vs the colours we see with natural or torch light, because of the fluorescent effects.
    Martyn
