Magic Filter/ISO Question
Started by n@utilus ·
  1. hi guys,
    i will be a first time magic filter user on my next holiday later this year.
    iam using d70+12-24mm+magic filter and just want to ask how should i
    set the ISO in this setup!?
    as it is natural light shooting should i set it to AUTO or manuel 200++ ??
    normaly i only use the lowest aviable which is 200 at the d70.
    TIA
  2. HI,
    I used the same combination in the Red Sea when on Alex's
    workshop I used ISO 200 & 400 & had some very good results
    the only problem I had was setting the white balance manually
    but now I have got a Padi photography state used it topside but have
    not tried it in the wet stuff yet.
    Andy :);):wub:
  3. Usually I don't use ISO higher then 400 since the D70 can be quit noisy.
    Andy, what was the problem with the WB? I found it quit easy with that camera.
  4. HI,
    the problem I had was when using a magic filter, I think the problem was more to
    do with gaining something white for the camera to lock on to, at times with strong
    currents with the camera opened up with a slow shutter speed. I can manage to
    do this every time topside thats why I got the slate only time will tell.
    Andy :);):wub:
  5. I usually use sand as the white reference and if I don't have it (as in Ras Mohamed ) I just set the WB against the area I'm going to shut, since I use RAW I can make a fine adjustments later but most of the times I finds the WB that the camera choose best or very very close.
  6. What is the PADI photography slate? I 've been looking for a good grey card to use UW but wasn't sure if the ones I saw at B&H were waterproof. I have a dive slate but he main issue with those is getting the camera to focus lock on a plain white subject. Last time I used the sand and it worked ok but still sometimes had trouble locking focus.
    RAW is the best. When I got frustrated with the process or the action was happenning I just shot away and fixed it later.
  7. HI,
    the padi slate has been purposely made for adjusting WB,
    one side is white & the other side is Grey. (it even has user
    instructions printed on both sides)
    Andy :);):wub::o
