EVO PRO Exposure
Started by wagsy ·
EVO PRO Exposure
  1. If you have an Amphibico EVO PRO housing and are having trouble with the manual exposure arm not connecting efficiently, then I would suggest you do the following easy fix.
    As each housing and camera is slightly different you need to adjust the arm but if that still does not work for you to well then add some sticky velcro or similar between the two little rubber bits. See the Pics.
