Bluefin FX1 Battery Pod Guard
Started by Nick Hope ·
  1. Well here's further proof that all those early teenage years watching Blue Peter weren't in fact for the youthful Sarah Greene and her rara skirts but actually for John Noakes and Peter Purvess and their wizardry with lolly sticks and sticky-back plastic. Honest! (anyone residing outside the UK, skip above paragraph).
    The background to this is that over 2 or 3 seasons I had 2 puzzling leaks on my Sunray battery pods (used on Stingray 2). In the end I wondered whether I had simply knocked or just leant on the battery pod doors and this had caused the leaks. The Bluefin FX1 itself is a nice chunky robust piece of engineering (dual o-rings, thick walls etc.) but I do think the older Sunray battery pod doors are a weak point in comparison. I would love to see a new generation of design that addressed the vulnerabilities. The light heads themselves are awesome however.
    My revolutionary, patent-pending new guard (widely tipped for next year's Duke of Edinburgh's Innovation Award) is made from the bottom of a plastic bin (garbage can to you stateside folk). It's mounted on the front of the pods using one of those pod locking wedge thingies (technical term) which arrived with my housing. I don't know whether LMI send this spare to all housing purchasers or if it was part of the service kit I ordered. To strengthen things up a piece of plastic chisel handle (the handle is plastic, not the chisel - a plastic chisel belonging the chocolate teapot school of usefulness) was mounted between the piece of pedal bin and aforementioned pod locking wedge thingy. I should stress that the handles of a wide range of hand tools would suffice. Er, perhaps I'd better let the pics speak for themselves (thoughtfully green-screened for you so you can superimpose on the background of your choice) ...
    http://www.flickr.com/photos/16987760@N00/...57594399941760/
    You need to drill 3 holes in the pod locking wedge thingy for 3 stainless self-tapping screws (not 5 holes, as possibly visible in my pic - I was dreaming of Sarah again and accidentally drilled them in the wrong place at first).
    The other pod locking wedge thingy is towards the rear of the pods, so basically 2 are used now instead of 1. There is no pressure at all on the pod doors.
    It works as they say, like a charm, and allows one to swim around with gay abandon, merrily shearing off the top of the reef without concern for the slightest scratch to your shiny equipment.
    Removing the guard is, as they say, as snap. Takes just a couple of turns of each of the 2 allens screws and you're done.
    I told you it would be knicker-gripping stuff. Your local tupperware store awaits. Heath Robinson, eat your heart out!
  2. Nick (Bubblevision),
    Thanks for the link to your ingenious guard for the battery pods. Will experiment with that, sounds like it'll be a snap to put it together. Cool!
    Btw, speaking of latches and guards... WARNING ABOUT BLUEFIN HD REAR PLATE LATCHES:
    Just when I though L&M did it right this time with the new latching mechanism on the Bluefin Z1 backplate (compared to the old 900, etc.), well my usual paranoia with leaks and latches came handy.
    I was diving last Sun off a boat here in Calif., I come up the ladder after I passed my Bluefin HD rig to the DM, and a few minutes later I notice - TO MY HORROR - that one of the latches on the rear plate has rotated 1/3 of a turn towards the OPEN position... Not clear when that happened, my feeling is that it may have happened when the DM put the rig on the table after the rinse tank.
    Luckily nothing happened, but my heart stopped for a sec.
    Background: I always - ALWAYS - use a a short piece of duct tape placed over the battery pods and the back plate latches on my Bluefin 900 housing. In many years of shooting, this simple trick has always worked well. I've never flooded a housing, pods, etc. (yes, of course I know I'm overdue)
    I'm also super careful when I get in the water and shoot, and when I give my rig to whoever's on the boat. But I guess you never know...
    After getting the new Bluefin HD, and seeing that the back plate latches have been dramatically improved upon, I thought that this time the back plate latches were 100% foolproof... And that therefore there would be no more need for the duct tape trick (to prevent kelp or people or whatever from accidentally rotate the latches).
    Well I guess I was wrong! After last Sunday's close call, I will keep using the "preistoric" duct-tape-over-latches trick for a long time.
    I may als call up L&M and report this problem so they're aware that their new latch system is not as infallible as we all first thought (well, at least I did).
    Just when I thought I could finally leave the duct tape home...
  3. Yes I wondered about those latches <_< ....no problems with the Phenom :(
  4. Bubble boy..
    Its nice to know your still swimming around with GAY abandon after your probs. Makes me feel all warm inside..Or is that just the .......... Add your own jokes here.
    Dive safe
    Dean(Sarah Greene :( )B
  5. Nick (Bubblevision),
    My first thought when I saw those latches was "Hmmm, looks like those could come off quite easily"
    I honestly wasn't impressed -- a simple knock on the springy thing does seem like it could open up.
    I never had an issue with the latches on the Mako housing except one time I made the mistake of diving Monastery Beach in Monterey, Calif and the beach is made from pebbles of just the right size to gum up the maximum amount of things (I am still getting them out of my gear months later)
  6. No problems with my Bluefin latches so far. These latches are streets ahead of the older all-plastic ones on my Stingray II. I think stronger springs might improve them even more though.
