Color Matching in Final Cut Express
Started by limeyx ·
  1. Here's the dilemma.
    I have some footage shot with two different cameras (one SD and one HDV) at the same time in the same place.
    However, I manually white-balanced the HDV camera way too red, and the SD was left on "auto"
    Now, of course, I'd like to use both sets of footage back to back in a Sequence (one set is a diver filming a diver filming and makes quite nice cut-backs etc)
    obviously the switch from one clip to the next is quite bad as in one the colors are all reddish/brown and in the other green.
    The green footage looks way better than the red (even though it is SD).
    I am wondering if anyone has any suggestions for filters/settings in FCE to bring the two close enough together so it will look reasonable, or if I just need to give up and either erase the whole lot or just try to fix the reddish/brown.
    here's a couple of screen grabs
    You can see the kelp is the main problem (red in one, green in the other) -- looks quite ugly at the transitions.
    Any help would be gladly received! (I can also post clips if that works better but I didnt want to chew up people's bandwidth)
  2. The only way to match them is to color correct. I'm not familiar with FCE so I don't know what they left out but 3 channel correction should fix that problem easily.
  3. The only way to match them is to color correct. I'm not familiar with FCE so I don't know what they left out but 3 channel correction should fix that problem easily.
    Thanks for the reply. I was kind of hoping for some guidance that was FCE-specific (i.e. what video filter would work best and which values are best to adjust etc.)
    I have tried the RGB filter but having a hard time matching it up
  4. Here's a piece on using "match hue" in Final Cut Pro 5 by Andrew Balis from Ken Stone's great Final Cut Pro website that may be applicable to FCE (I hope?!) "Match Hue" is found in the Color Corrector 3-Way filter.
    Mary Lynn
    Edited by Mary Lynn
  5. Here's a piece on using "match hue" in Final Cut Pro 5 by Andrew Balis from Ken Stone's great Final Cut Pro website that may be applicable to FCE (I hope?!) "Match Hue" is found in the Color Corrector 3-Way filter.
    Mary Lynn
    Thanks so much. Gonna check it out.
  6. Hmmm, on first glance the match hue seems not to be in FCE.
    However, I found a laymans approach. Add a video filter of type Quicktime/RGB
    set red to 60, green to 110-150 and blue to 130-150
    Seems to do a reasonable job (well, good enough to convince me the footage is saveable. I will tinker with the exact params later during editing)
    Have to check it still looks good in large size also, but I am hoping it will.
    still, thanks for the info.
