Extention ring for 12-24?
Started by Christian K ·
  1. Is an extention ring reccomended for the 12-24 on my D200 in my hugyfot housing with hugy dome port?
    cheers
    Christian
    Edited by Christian K
  2. Yes, you need extension ring ref. EXT-6.275 if you use dome port WAP-6.290.
    But no extension is required with the dome port ref. WAP-6.295.
  3. Yes, you need extension ring ref. EXT-6.275 if you use dome port WAP-6.290.
    Don't know which ref # on the port (does it say somewhere?), but it is app. 18-19 cm in diameter.
    /christian
  4. That seems fairly big. The largest port available from Hugy currently is a fisheyport with a diameter of 17.4cm (although they do accept ports from other manufacturers with an adaptor). If that's the one you have, you'll need a longer extension, probably a 60mm (ref. EXT-6.432). I suggest you check with your local distributor to confirm the reference of the port you own.
  5. That seems fairly big. The largest port available from Hugy currently is a fisheyport with a diameter of 17.4cm (although they do accept ports from other manufacturers with an adaptor). If that's the one you have, you'll need a longer extension, probably a 60mm (ref. EXT-6.432). I suggest you check with your local distributor to confirm the reference of the port you own.
    Yep, that's the one I have. I ordered it for the 10.5.
    thank's Mathias
    /christian
