Eos 30D with Inon X2 ??
Started by serge ·
  1. hi!
    i will go to japan end of this month ... and of course i want to use this possibility to do some shopping and maybe upgrade to slr.
    i specially like the INON X2 for the eos 30d ... the first housings should be delivered now. i really like the idea with the magnetic focusring and the 45 degree viewfinder also looks good. and it is handy ...
    apparently there are 2 ports with magnetic focusrings: for the ef-s 60mm and for the ef 100mm ... and a dome for the 14mm (or 15mm?) fisheye ...
    anyone tried the x2 already or heard something about it?
    and did anyone try the macroport with the m67 closeuplens, that can be srewed in front of the port? i would like to know how good it works ... if good, then maybe the 60mm plus the closeuplens could be a good option, if i only want to buy one macro port.
    and for the wide: inon says, the dome will be for the canon fisheye ... does that mean, i cannon put another (more extreme) fisheye from another manufacturer inside (i think about the sigma 8mm)?
    and finally: is the 30d a good model to choose? the d200 seems to be the leader in all forums ... but i like that inon housing ...
    hopefully there is somebody who can help me with at least some of these questions ...
    thanks, serge
