FL20 in PFL-01 for 350 ???
Started by visa ·
  1. Ciao,
    I am new here, and I am from Italy.
    a QUESTION TO sP-350 OWNER: anyone is using FL20 in PFL-01 set with Oly SP-350 if yes, with which results ?
    I am thinking to this set, even 'cause I could use it on land....
    Thanks AND ciao
    vito
  2. Ciao,
    Thanks AND ciao
    vito
    Hi,
    I'm new to underwater photography as well however I've been using the setup that you're descibing. Personally, I like the hardwired TTL underwater. Gives me one less thing to worry about. The flash itself is fairly strong, allows for rapid cycling of the camera because you can turn off the internal strobe and does an acceptable job on portraits and macro. In any case, I'm glad I started with it. Here's a link to some of my photos...not the best but it should show you the lighting. The other nice thing with it is I'm now using it with another optical flash which fires off the housed FL20. Opens up the WA shots for me.
    http://www.cupsonline.net/MembersShowOff/M...34/Default.aspx
    Gary
    Edited by ce4jesus
