Please help me choose my first UW digicam
Started by kittykat23uk ·
  1. Hi Everyone. After much researching, hesitating and general faffing, I'm decided I really want to get a digital camera this year. Now, my criteria are:
    £300 to £400 price range for camera and housing with the ability to add on a strobe at some later date.
    I want a camera that I can use both under water and for taking shots of wildlife, birds, reptiles, mammals etc. I have a telescope so one that I can use to digiscope with would be very useful. This involves mounting the camera to be in line with the eyepiece of my scope, therefore this resricts the size of the lens in the camera and some of the most compatible models seem to be the FujiF30 and F31, and Canon A540, A640 and A710IS.
    So, I've been looking at the above models and they each seem to have their pros and cons. I'm leaning towards either the Fuji F31fd or the Canon A710 IS, because the canon has optical Image Stabilisation and the fuji has a picture stabilization mode.
    Good points with the Canon A710IS
    * 7.1 Megapixels
    * 6x optical zoom with optical Image Stabilizer (35-210mm equiv.)
    * DIGIC II, iSAPS, 9-Point AiAF, FlexiZone AF/AE
    * Digital Tele-Converter and Safety Zoom
    * 2.5†LCD with wide viewing angle and real-image optical viewfinder
    * 20 shooting modes including underwater mode.
    1cm Macro- I also paint and photograph wargames miniatures so a good macro mode would be a bonus.
    This was the summary of the review at DP review:
    Conclusion - Pros
    * Good resolution
    * Clean and detailed results across the frame and zoom range
    * Useful 35-210mm equiv. 6x zoom lens
    * Effective image stabilization
    * Fairly light noise reduction means less fine detail is lost at higher ISO settings (though see below)
    * Fast, reliable focus
    * Reliable exposure and white balance and accurate color (though a bit too 'vivid' by default)
    * Sophisticated and comprehensive features and controls
    * Good range of in-camera tonal and color adjustments
    * Excellent build quality for a 'budget' camera
    * Very little purple fringing
    * Compact and lightweight
    * Big, fairly bright (though low res) screen
    * Excellent battery life from 2x NiMH batteries
    * Good balance of noise reduction and detail retention at higher ISO settings
    * Excellent macro mode
    * Excellet movie quality
    * Optional add-on lenses, filters, 40m underwater case and slave flash
    * Good value for money
    Conclusion - Cons
    * Highlight clipping and occasional over-exposure in bright, contrasty conditions
    * Combined card / battery compartment can make changing cards without losing the batteries fiddly
    * Zoom is a bit jumpy (not enough steps between 35 and 210mm)
    * No dedicated button for ISO and no custom modes / shortcuts
    * Our sample had occasional auto orientation errors (landscape shots being tagged for rotation unnecessarily)
    * Slow flash recycling (and fairly slow shot-to-shot times in general)
    * Low res and very slightly laggy screen
    * Images a bit soft viewed at 100% - benefit from a little sharpening
    * ISO 400 and 800 do look quite noisy
    Overall conclusion
    Canon's A series PowerShots get better with each generation, and - thanks to the inclusion of extensive photographic control and technologies such as DIGIC II and image stabilization has lifted cameras like the A710 IS firmly out of the 'entry level' bracket they originally occupied.
    The A710 IS takes the formula established with the A700 - well-priced, compact camera with big zoom and full photographic control - and adds the one thing that was missing, an effective optical image stabilization system. And in doing so it makes a good camera immeasurably better. The extra megapixel offers little if any real advantage; the resolution is increased slightly at ISO 80, but at higher ISO settings the slightly stronger NR soon gets rid of that.
    Whilst there are other small cameras with big, stabilized lenses (most notably from Ricoh and Panasonic) the A710 IS has virtually no direct competitors thanks to an extensive feature set that offers enough to tempt the more serious photographer. Like all recent A series models it offers an awful lot of camera for what is (for Canon at least) a very low price. The output quality is surprisingly good, exposure (mostly) and focus reliable, and the amount of photographic control on offer is superb. The ability to further expand the A710's abilities with add-on lenses is also a definite plus point.
    Of course it's not all good news; you have to watch the exposure and use AE compensation more than I'd like in bright, contrasty outdoor conditions - something Canon really needs to address. And the screen may be big and fairly bright, but it's not fantastic - the slight lag and low resolution are the compromises you have to accept if you're not shelling out for an S or G series. You also don't get custom modes, shortcut buttons or an external ISO control, or (less crucially) the latest fancy transition and playback effects.
    But you do get a nicely designed, nicely built camera with more than enough features to keep most users happy. It's no surprise the more recent A series PowerShots have often been dubbed 'Mini Gs'.
    Canon has carved out a nice little niche with the A series; workmanlike (I would say unglamorous, but the A710 IS has significantly improved styling), solid, dependable and affordable photographic tools that just take good pictures without too much effort. The A710 IS even manages to be truly compact, and it has something most A series models don't; character. It's the first A series I've used that I didn't simply admire for its reliability and excellent price/performance ratio. The A710 IS is actually a very nice, rewarding camera to use - sort of like a perky little brother to the PowerShot S3 IS.
    If you don't mind it not being the fastest 'social' snapshot camera in the world (the flash recycling puts paid to that) and don't mind taking control of the manual controls (at least the AE compensation) when shooting on very bright days, this may well be just the camera you've been looking for.
    Without the metering / clipping issues this would be an easy Highly Recommended. As it stands its unique combination of features and keen pricing just saves it from a lower rating. I wouldn't hesitate to recommend it to the more experienced photographer on a budget wanting a compact camera packed with goodies, perhaps less wholeheartedly so for the absolute beginner wanting true 'point and shoot' infallibility. "
    A full review can be found here: http://www.dpreview.com/reviews/canona710is/
    I am a little concerned about the Flash recyc. times and general speed of this camera, Could anyone who knows anything about cameras help me to determine whether this would cause a major problem for UW work?
    The Fuji F31fd on the other hand has the following features: http://www.dpreview.com/reviews/compare_po...thod=sidebyside
    But there is no in depth review. The user reviews I have read say that it is very fast, and more rugged than similar spec canon cameras.
    Any views on the pros and cons of either of these cameras most welcome. Although I'm still open to other ideas..
    Jo
  2. I am a little concerned about the Flash recyc. times and general speed of this camera, Could anyone who knows anything about cameras help me to determine whether this would cause a major problem for UW work?
    Hi,
    Welcome to Wetpixel. I think if you do a search on here on your Canon and the cameras I've listed below, you'll find extensive debate on all upside and downside of each camera. It looks to me like your budget of about 400 pounds would allow you to choose from a variety of point and shoot cameras with housings. As your above statement indicates, most point and shoot models suffer some sort of lag. Whether that lag is flash recharge times, write times of the image to memory or even focusing times, each manufacturer does better in different catagories. Many on here are using Canon's and might be able to comment on the camera you've chosen but there are others to consider.
    Sea&Sea DX8000G
    Olympus SP350
    Fuji E900
    Are just 3 that would also fit inbetween the extreme ends of your budget. Check Wetpixel classifieds. My suggestion is that if you have the time, go play with the new display cameras in the store. I practiced trying to focus on different subjects, someitmes low contrasting subjects, with the internal flash enabled and the camera set to the highest picture quality available. I would then see how fast the camera took the initial picture and how fast it was ready to take the next.
  3. I'm leaning towards either the Fuji F31fd or the Canon A710 IS, because the canon has optical Image Stabilisation and the fuji has a picture stabilization mode. ...
    The Fuji F31fd on the other hand has the following features: ... But there is no in depth review.
    1. Fuji F31fd is identical to F30 for all practical purposes (fd is "face detection", and since fish faces are different from humans, it's unlikely to make a difference u/w). Try doing a search for opinions on F30 (I for one posted a non-recommendation of it if you plan on using an external strobe).
    2. "Picture stabilization" in F30/F31 is just a misleading marketing name for a high-ISO mode (which, to be fair, is very good in F30). However, I'm not sure how useful a true optical image stabilization (as in Canons) would be u/w, since you'd want short shutter speeds for fast-moving fish anyway. Hope this helps.
  4. Of the two you're looking at, only the Canon has a true manual mode. Very important for U/W.
    Mike
