Roatan Honduras
Started by yahsemtough ·
  • 12Posts
  • 12Replies
Roatan Honduras
  1. This shot was taken in RAW at F8 1/500 with 90dx dual strobes set to -4.
    I use the cp5000 in the Aquatica housing.
  2. I definitely don't have much room to speak, but as a newbie who shoots topside I'd say:
    the good: subject, cropping, background, color
    could improve: subject looks a little soft and lighting casts some shadows on the lower body, maybe shooting more inferior to the subject would help too (just some thoughts)
    very good overall :unsure:
  3. Thanks for the comments. I believe the downsizing had a bit to do with the softness as the original is sharp. I guess I really need to look inot linking instead of attaching.
  4. How are you reducing your images Todd?
    This one is reduced from some humungous size down to 55 kb's
  5. Cybergoldfish,
    hmmm, maybe another good question would be how are you reducing your images . . . looks excellent, please share wisdom.
  6. Eh Todd, don't you just hate Bob. You post a decent pic & he always replies with a competition winner!!!
    Anyway nice pic. Sharpness is also missing on my monitor. Confirming what Bob has said, you must be losing too much on the compression. I always edit as much as you need & then resize accordingly.
    Mark
  7. I did the edit in Tiff then resized down to what wetpixel would allow for an attachment. I believe I had to resize twice after I thought I had already got it small enough to attach.
    Maybe the couple resizes are the problem.
    The TIFF starts at 1650 by 2154 and 10.1M
    The resized JPEG is 325 by 425 and 35K
  8. I just tried to repost the Octopus as it was for some strange reason not showing anymore. When I resized it down as the same picture was denied I see that it appears to have lost some sharpness. It must be the old JPEG compression.
  9. Todd, you will have lost some on the double resize. When posting pics in landcsape mode I always set the pix width to 600. I portrait mode I tend to set it to 500 height max. I keep these settings thus precluding the need to double resize etc. If you do need to resize twice or more then UNDO your last actions thus retaining the previous picture quality.
    In addition, I assume you set the level of compression when saving as JPEG. With PSP I can do this as there is an options button on the save as command which allows control on the compression.
    Intersting TIFF size 10meg. What was the RAW file size?
  10. I'll try another. I think it is when I proof it in Breezebrowser. It puts it over the limit on me.
  11. As Mark said you must go to "IMAGE - IMAGE SIZE" Then reduce the image by pixels not compression this way you lose nothing much
    I normally post like so:
    TIFF/PSD/Whatever.
    Image - image size 600 x ?
    dpi 100 or 72
    Then save as .jpeg @ around 50 - 70 kb
    You will notice if you save at 60 kb when you try and upload it it has grown to 63 kb or so - spooky!
  12. I do use the process you mentioned. But, when you go to breezebrowser to copyright it then saves a proof. I think in that process it ups the K and thus, it is a save in jpeg so it reduces the quality. So, I need to also use breezebrowser before the save to jpeg I believe.
    Plus, thanks for your email comment. I will adjust and try that as I do appreciate those critiques.
