Mixing DV/HDV in same project Prem Pro
Started by Roger Eve ·
  1. Hi Guys,
    Just a simple question from a HDV beginner. Is it possible to mix DV with HDV in the same project using Prem Pro2? If so, can anyone explain in simple terms how it is done. I would be outputting to DVD, probably ISO file then Nero to burn the disc.
    I would probably being needing to do this after my trip to Kenya, i.e. safari animals on the FX7 and the u/w stuff on my Sony 330E - while waiting for FX7 housings.
    I welcome any comments.
  2. I've just downverted (in camera) to DVCAM and dropped it onto the timeline..
    Premier 6
    Looks great...
    DeanB
    Edited by DeanB
  3. You can mix formats on the same timeline, for example combining DV and HDV footage at 480, 720, 1080 lines, and then edit and preview directly in Premiere Pro 2, with real-time preview as possible based on the performance of your system.
    There are other NLE's that will do it better in real time though.
  4. Thanks to all,
    Great information and very quick too. Much appreciated.
    Best wishes
    Roger
  5. No Probs.
    Now if you want no fuss slick editing DV 4.3, 16.9 or HDV on the same timesline with realtime effects then there is no other than EDIUS. :P
    And if you want to upconvert a DV clip to HDV res, just right click on it in the bin and it can do that as well.
  6. EDIUS THE BEST A MAN CAN GET :P
    Dive safe
    DeanB
    Edited by DeanB
