Lots of flicker on stills, how to remove ?
Started by skawdiver ·
  1. Need a little help.
    I am making a project where I use screendumps from websites, and animating them via key frames.
    But there is a lot of flicker in the graphics.
    How do I get rid of that, and have smooooooth graphics moving across the screen.
    I have tried render as progressive, but that did'nt help.
    Any advice would be nice.
    I am on Vegas7
  2. Things to try:
    1. "reduce interlace flicker" (right click on event > switches)
    2. Make sure you're using "blend" or "interpolate" de-interlacing methods in your project properties if you're trying progressive
    3. Add a little gaussian blur effect to the events (horizontal 0, vertical start at 0.001 and increase if necessary)
    4. Reduce the opacity of the stills a little (drag down envelope from top of event)
    5. For white graphics reduce white levels from 255-255-255 to something like 235-235-235
    Let us know what works
  3. Things to try:
    Hi Nick,
    Thanks for your fast reply.
    I have tried your advice, and they helped, but not enough, there is still to much flicker in the graphics.
    However, I have to drop this project, as I am making a DVD for tonight, I am presenting my latest films in our local diveclub, so I have to start making the DVD now, or else I might not be finished in time.
    So I will play with the settings later.
    Thanks agian :P
    Edited by skawdiver
  4. Prem Pro you have to add the flicker filter as well.
    I hate to say it but the ones I have done with you know what work no probs. :P
  5. snickering at Wags....
    Sorry, i can't help, haven't done that before
    Edited by MikeVeitch
  6. Okey, I did'nt manage to put it into my project today, cause I had to start the mpeg2 encoding for tonights show at the local diveclub.
    -but I have been playing with it afterwards.
    Best results with:
    - Render quality: Best (this is very importent)
    - "reduce interlace flicker" (right click on event > switches)
    - Reduce the opacity of the stills
    Edited by skawdiver
