I tended to enjoy a large degree of success with running the Ikelite EV controller and the DS125 set to ttl, obviously this is all manual strobe use. Going from full wreck vistas to shooting pygmy seahorses on the same dive with quality pictures was quite fun. Lens, focus speed, that was lacking.
With hesitation, I moved on and I sold my Ike/CP8400 to a friend but recently asked Ikelite if they had figured iTTL circuitry for this camera or not? I was told no. I was hoping they did so my friend had the choice either way.
To my understanding, and from the lack of Ikelite providing much further discussion on this camera, I believe that Ikelite has simply moved on past this camera (and almost did from the beginning). I don't ever see Ikelite providing any effort to put circuitry into this housing because there is not enough demand. I do not see it being a "enough room" issue as the lastest batch of Ikelite dslr housings are thinner in the main body, but the rear housing panel is similiar thickness to the CP8400 and they have simply carved out a section for the circuitry to be inset within it. There really is no reason that Ikelite couldn't receive your housing and inset the circuitry board within the backpanel as the dslr systems (if they wanted). In my opinion, Ikelite simply looks at this as "why?". To my knowledge, I know of only 4 people who shoot this camera u/w, so for Ikelite to take manpower to make this happen isn't cost effective on a camera that is more than two years old.
That's too bad in my opinion, I think the market overlooked what to me is far and away the better of most all compact digicams to be produced to date. You has extremely good macro, 24 mm (film equiv) wide-angle photography (all on the same dive!), ttl viewfinder, 8mp with RAW, complete full manual control, and a host of other features right out of the box without any additional lenses or add-ons; still not yet equalled in the market even after two + years.
I would suggest a serious look into the Heinrich circuitry for this if you need TTL, there is room in the corners and along the back of the housing should you want it and hopefully Heinrich's works? You will need the help of someone like Ryan to install it and not muck it up. At least you have a bulkhead there waiting....
Good luck.
