Experience with hookha systems
Started by js472 ·
  1. I am thinking about using a hookah system on my next trip and I would like to know your thoughts about different models or the concept itself.
    Thank you
  2. What are you thinking about using it for ?
    Hookha (if thats how it is spelt) are purely a drop reg for emergencies. I have even seen them with 6-8 octo's on them.
    If you are planning on diving with a fixed airsupply from the surface you are looking at Snuba.
    In which case this was meant for shallow 40ft diving for small periods of time (say 30 minutes) as you have no indication of your air supply.
    I would recommend the tank supply version on a float:
    http://www.snuba.com/equipment.asp
    Generator prodivided air sources are just dodgy !
    But really ... I used snuba every day for 4 years doing fish feed. It's no simpler or easier than scuba ... I would just put a tank on and allow myself pull freedom.
    MHO .... Giles
