Point & Shoot settings
Started by davidebt ·
  1. Hi I'm new to the forum and to UW photography.
    Just bought a Sony DSC W7 and UW case and would like to know waht are the best settings to use on a digital camera when snorkeling / shallow diving. travelling to the Red Sea next week.
    Have got a magenta filter with the UW case.
    Any feedback appreciated
    Regards
    David
  2. Welcome to Wetpixel!
    Leave the camera on automatic. Turn the flash off. If you use a filter, you will probably need to use - 1/3 to - 2/3 exposure compensation. I highly recommend the Magic Filter.
    If the camera has aperture priority, use the smallest aperture (highest f/ stop number) that still gives you 1/60 second or faster.
  3. actually i would suggest putting the camera on P mode if indeed your camera has that function. Desert Eagle has a good suggestion with using negative exposure compensation, i would even go so far as -1.
  4. Hi I'm new to the forum and to UW photography.
    Regards
    David
    Thanks for info. Will give it a try and post some pics on return if ther're anyn good
