Problems with DS125
Started by sea_ledford ·
Problems with DS125
  1. This morning I turned on my ds125 and it started to make the typical whine as it powered up but then stopped abruptly about half way through it's charge cycle. Then it wouldn't flash. The modeling light turns on. The modeling light turns on and it tells me I have a full chage when I put it to test, and when I try to fire it, the indicator light on the side turns green for a second before going back to red. But it dosen't flash. And the ready light won't come on either.
    The kicker is this is the SECOND time this has happened to the strobe within six months! Last time I sent it back and it had a bad/burnt oscillator board (whatever that is).
    Anyone else had this problem?
    Chris
  2. can't say i have had the problem but Ikelite is well known for being able and willing to fix it asap. I would suggest sending it in.
  3. I've never had any problems at all with my DS-125 strobes but as mike said, let Ikelite know about the problem and they will make it right.
