Guys, I may have a problem and I really need you help. So please read this and post your experiences/advices.
I own new olympus C-7070 camera and new Olympus pt-027 housing for it. I haven't tested it in (deep) water, but I have tested it in childrens bathtub. It doesen't leak to the camera, BUT it does "leak" to back of the O-ring. See left picture below.
My concern is that since the O-ring is symmetric and the place where O-ring is (square) is also symmetric, If water leaks to upper part of that square, it may leak to bottom part of square and from there into camera (see right picture).
My O-rings are new and I have triple checked them (for hairs,sand, etc.) and I have greased them well with silica gel. I noticed that if I put lots of silica gel it doesent leak so much, but I read that too much silica also causes flood.
My main questions are?
1) Does water go to back of O-ring in your housing as well? (you can see it easily when housing is in water)
2) Is it dangerous i.e can it cause flooding in greater depths?
I have called olympus about this, but they have no idea. I am going to philippines for 1 month and if my camera floods there, my diving trip is quite ruined since its quite impossible to get a replacement from there!
Please post your comment guys!
Thanks in advance ![]()
