Cayman turtle
Started by The Octopus ·
Cayman turtle
  1. post-8758-1173018402_thumb.jpgI shot this in Little caymen 11/06, and am not happy with the blue tinge any help to eliminate it would be appreciated.
  2. What do you mean by blue tinge? Color looks ok to me, if anything, it is a bit too red.....
  3. What do you mean by blue tinge? Color looks ok to me, if anything, it is a bit too red.....
    on the edge of the turtle, thought it was chromatic aberration but doesn't correct.
  4. Looks fine to me on this web version also ..
    ... i don't see any blue tinge ... maybe a 100% crop of the problem you are seeing may help ..
    Giles
  5. Looks fine to me on this web version also ..
    Giles
    just a small flash of blue on the head. looking at the photo to the left. the rest is fine. I must be nitpicking.
  6. Ok, I see what you're talking about. That is actually a just a shadow. (Shadows are blue because ambiant light is blue.)
    If you're not allready, using two strobes will help to minimize shadows.
  7. Ok, I see what you're talking about. That is actually a just a shadow. (Shadows are blue because ambiant light is blue.)
    I do use 2 flashes, must be aiming issue.
    thanks
  8. Your left strobe wasn't firing very well then ...
    look at the shadow caused by the fin ... that would not look like that if the left strobe fired.
