D80 in D70-housing
Started by DuikKees ·
D80 in D70-housing
  1. I am thinking of remodelling my Ike D70 housing for a D80. Anyone tried it already?
    I compared the two camera's and it looks like most buttons and controls are on the same place. The D70 is only a bit higher, which is easy to overcome.
    Here are some quick and dirty comparisements based on the mount position.
    Edited by DuikKees
  2. Kees,
    you will loose your beloved 1/500 synch...
    changing the controls (and decoding the ttl) is what ikelite does as well, i suppose. I have no idea how difficult it is to change almost every button (it looks that way, 0,5 cm bigger or smaller will mean a lot.).
    At least you will see where controls go wrong with an ikelite housing... There is a thread on somebody changing a 350D to a 400D housing (Sea and sea). The push buttons didnt seem to take much work there.
    is ikelite's circuit tailored to the camera ? (otoh, you were using Heinrichs converter)
    Gerard
    PS: in the end i did buy DS-50 strobes, so i didnt have need your help on the old strobe use part.....
  3. Make sure you post details if you succeed (well... also if you fail).
    I'd be inetrested to do the same with my housing.
  4. Hi -
    I retrofitted a d80 into Nexus d70 housing last fall. here are U/W photos..
    fishlens.com
    click guadalupe
    Depending on the housing,you will need new tray and some modification of control arms..but, it is possible.
    M.
    Edited by Starbuck
  5. but, it is possible.
    M.
    That's the news I want to hear. -_-
    Do you also have some pics of the modification?
    P.S. you're site is ofline... :(
  6. Hi-
    No pics of housing, it would not look much different than original. I machined new tray and removed some control arms to get everything to line up. The most difficult part was aligning lens with center of port. In fact, I have a d80 housing from nexus which is an old d70 housing. Nexus was using up inventory and I got one of the first ones. You'll love d80 over d70...unless you need electronic shutter.
    Site should be up...unless Apple is doing maintenance..try again.
    M.
  7. This sounds interesting.
    A friend of my just bought D80, I’ll try to check it also and see hoe much work needed if possible.
  8. This is encouraging!
    My neighbourg is thinking about getting D80 soon. I need to push him to do that quickly and then let me try fitting it inside my housing.
    It would be great if I colud make some sort of adapter that could be removed. I could keep D70 as a backup camera.
