o ring brainwave
Started by Cerianthus ·
o ring brainwave
  1. I think i had a good idea today and want to share this, using a guitar plectrum as an oring pick.
    They tend to be off plastic, and are a bit thinner and easier to handle then a credit card.
    Haven't tried it, but i will i the near future. was just a tought.....
    Gerard
  2. sounds like an obvious choice ..
    i love the plastic tool Sea&See give you when you buy any of their products.
  3. I think i had a good idea today and want to share this, using a guitar plectrum as an oring pick.
    Actually in the U.S. it would be a guitar pick as an o-ring plectrum -_-
    Might be interesting based on the pick thickness and the shape, some may be too thin to do the job, I use the yellow ones of these
    http://www.jimdunlop.com/index.php?page=pr...=products/picks
    Nice grip, non-slippery and will work (at least it did a couple of times I tried it), also works in clearing off salt and build up.
  4. For some of the bigger o-rings such as the housing's main o-ring, you may be able to just use your thumbs to push two segments towards each other and that will pop the intervening segment out. -_-
  5. the main o ring and the port oring are not the ones i am worried about. It's the ikelite sync cord orings. I now use a combination of pushing them out with my fingers, and then stickig a metal dental pick between the o ring and cord (to save it from being scratched).
    In the sync cords, the screw cap is a little in the way to do this comfortably...
