Cowrie from Lampung Indonesia
Started by V_kids ·
  1. HIIII
    i took this cowrie pic couple weeks ago.
    I was using DX-D50 + YS 90 auto 2 unit + Nikon 60mm macro lens.
    http://myimgs.net/images/umxi.jpg
    Please tell me what do you think about this pics? what should i do to improve this pic?
    no PS at all, only resize it...
    THx you in advanced
    Andree
  2. I cannot access the link
  3. The colors are nice and exposure is good but a 105mm macro would have been a better lens choice, the subject is much to small in the frame and also heavily obscured. The shallow depth of field casing the blurred obstruction and the subject being so small causes no impact for the viewer. I would suspect 99% of the non UW photographic populatation would not have a clue as to what they were looking at. On the positive site the colors are compelling to keep them looking while they scratch their heads.
  4. The colors are nice and exposure is good but a 105mm macro would have been a better lens choice, the subject is much to small in the frame and also heavily obscured. The shallow depth of field casing the blurred obstruction and the subject being so small causes no impact for the viewer. I would suspect 99% of the non UW photographic populatation would not have a clue as to what they were looking at. On the positive site the colors are compelling to keep them looking while they scratch their heads.
    Both the 60mm and 105mm macro lenses focus to 1:1, and i think this image is shot at near 1:1 from looking at the soft coral., and thus the 105mm would have made no difference to the size of the cowrie in the frame. The 105mm would have given you more working distance though.
    If you really want to shoot the tiny stuff like this at full frame then you'll need some teleconverters and probably the 105mm to give you the increased working distance, but then you will be diving a very specialised dive, and you are bound to see manta rays and whale sharks whilst you are stuck in super macro mode!
    The position of the cowrie isn't conducive to good composition, maybe next time take a couple of shots, then have a look around at some other stuff and come back later on to see if it had moved?
    Did you bracket with some different composition? maybe post those too so we can take a look.
    The exposure is good and i like the colours, but sometimes the critters aren't in a photographic mood and all we can take is a snapshot, it's still a nice shot for ID purposes though.
    May i also suggest that you look at some other image hosting sites as that one has watermarked your image, and doesn't seem to give a link to your album. Flickr is a popular one.
    I hope this helps!
  5. Something completely heretical, you might select the cowrie and do some slight tint changes to separate it from the background. I know this takes away from the purity of the image, but it will help non-divers see the critter. The other way to go is to select the cowrie, reverse the selection and drop the saturation on the background. I'd mess around with the crop also, but doing one of the two things I mentioned will draw the eye.
    Photo purists don't hate me :)
  6. Something completely heretical, you might select the cowrie and do some slight tint changes to separate it from the background. I know this takes away from the purity of the image, but it will help non-divers see the critter. The other way to go is to select the cowrie, reverse the selection and drop the saturation on the background. I'd mess around with the crop also, but doing one of the two things I mentioned will draw the eye.
    Photo purists don't hate me :rolleyes:
    Hmmm, if you don't mind it being a little less than authentic you could also draw attention to the cowrie like this . . .
  7. yes :rolleyes: i think that's it. perfect
  8. Hi All!
    Sorry i wasnt able to check this forum for a while.
    i was out of town ( with no internet connection)
    thx you very much for all the input, it's very interesting ^_^
    YES, i was having a hard time dealing with the lighting...
    the working distance with Nikon 60mm macro lens was too closee
    very hard to manage the lighting
    Next time i will use my sigma 105mm for cowrie
    (Many Cowrie in this dive spot, most of them located at 40-45feet only)
    it;s not hard to find them
