shawdow
Started by kentmorrdave ·
shawdow
  1. I use a Canon A620 with there assigned housing. I come across this shadow sometimes:
    Can someone explain this? Thank you in advance. :wacko:
    Edited by kentmorrdave
  2. if your housing or dome port has any type of protection/feature which sticks out, this can block light from your strobes if they are placed to far behind or too low in relation. is this a possibility?
  3. What housing do you use?
    Sometimes a diffuser on the internal flash can helps.
  4. To my eyes, this is clearly shading from port. You will need to zoom your lens in a bit to crop it out of the field of view.
    If you look at the housing you can see exactly what is causing it:
    Not the photographer's fault.
  5. Is the housing design really that bad ?
    I'd be interested to hear if zooming in a bit does avoid the shadow.
  6. I used to get a similar shadow when my internal strobe would fire with my WA lens on so I would guess that is from your internal firing. The shadow is the lens port. My guess is you don't have an external strobe.
