INON and ULTRALIGHT Arm Compatibility
Started by rogerhorrocks ·
  1. Hi all, are the balls on the INON and ULTRALIGHT systems the same size? I have two INOn Z240's with INON connectors which I want to combine with ULTRALIGHT buoyancy arms - will they work or do I need to order the ULTRALIGHT connector for the INOB Z240? Based in South Africa, so no way to physically check. Thanks in advance.
    Edited by rogerhorrocks
  2. yes they are interchangeable. They both use the same size balls.
  3. Yes. In my experience.
  4. Yes, I also, use Inon strobes with Inon Z type 1 inch ball adapter connect to ULCS arm, using ULCS AC-CSF or Inon Clamp. No problem at all.
    Sam
    Edited by shchae
