Ikelite Strobe: TTL Slave sensor, Tray, Arms - 4Sale
Started by lanwu ·
  1. Will ship overseas. Payment & shipping costs can be arranged for interested parties.
    http://bangkok.craigslist.org/pho/296433666.html
    Ikelite Arms & Tray
    ... - Tray Arm: 11 inches
    ... - Tray Arm extension: 4 inches
    ... - Extension Arm: 13 inches
    ... - All parts as seen in photo
    Ikelite Underwater TTL Slave sensor:
    ... - Eliminates the need for a dual sync cable in dual flash systems and provides full TTL functionality.
    ... - Triggers from the internal flash of cameras with no external flash connection.
    ... - Max. Operating Range: approx. 15m underwater (sensitivity adjustable).
    ... - Must be connected to Ikelite DS-series Substrobe, but can be triggered by a master flash of any make. Detects firing and quenching of master flash, and signals the Substrobe to fire and quench in sync. with it.
    ... - Exposure accuracy: ± 1/10 EV.
    ... - Mounts on standard Ikelite ¾" diameter arm stem or tube. Other mounting options discussed below.
    ... - Dimensions: Body diameter (at front window): 45.5mm, Front to back: 79mm, Height inc. mount: 105.6mm
    ... - #4100.5 TTL slave sensor for Ikelite DS-series ("digital") substrobes (DS-50, DS-125).
    ... - Reproduces digital camera pre-flashes.
    ... - 4100.5 connects with DS-series strobes only.
    ... - Powered by the DS-series substrobe. Does not require batteries.
    ... - Pre-flash intensity switch (4100.5): Located beneath removable plug with coin slot.
    ... - Right position (shown) is for cameras using pre-flash. Provides long pre-flash to reduce chance of overexposure.
    ... - Left position is for cameras which do not use pre-flash. Also provides shortened pre-flash with pre-flash cameras, increasing exposure.
