Ike port for Tokina 12-24
Started by aczyzyk ·
  1. Ikelite site recommends #5503.51 port for Tokina 12-24.
    I already have #5503.50 and #5503.55 ports which seem very close to it.
    Do you know if it works fine with any of these two?
  2. Ikelite site recommends #5503.51 port for Tokina 12-24.
    The 5503.50 works fine with it. I have used that port for both Nikon and Tokina Versions.
  3. Andrzej (and Chris),
    Chris has used the Tokina 12-24mm in a #5503.50, ao it must work. Slight difference is really in the internal barrel diameter. Very, very small difference due to molding and as such the zoom might be a bit tight in a #5503.50.
    Give it a try and if you don't use the zoom clamp and ring, set one angle and go shoot as long as it physically fits.
    Good luck!
    dhaas
  4. Thank you.
