Hi,
I took over 500 macro test shots to see the diffrence in two cameras
but, these two cameras are basically shows same quality pictures
in general. I was hoping to see BIG difference since Fuji advertise
S5pro has 400% dynamic range but, I do not see it (IMHO)yet.
One thing I felt bad was slow 'reviewing' time on S5. I am used to D70 &
D200's instant review (you can see result of your shot immediately
so that you can continue take more pics with same setup or change
f-stop,WB or ISO right there.)
S5 has option to select the time (I do not know why even it is an option) &
shortest time you can select is 2 sec. & I felt this 2 sec. like shutter lag
on some of earlier P&S cameras. other than that, again, I do not see
big difference.
I was using 105mm VR w/Woodi's diopter & both camera shows same
focusing habit is dark area( I guess they are using same CAM1000).
Speaking of Woodi, I met him while I was taking test shots. He is still
there in Anilao this week.
Here is pictures;
S5Pro/D200 in Nexus D200 housing + 105mm VR + Single housed SB-800 in 'TTL'mode.
Red Fire Goby Long Nose Hwak Fish
S5Pro D200 S5Pro D200
