Zeagle Ranger LTD BCD size MD
Started by yahsemtough ·
  1. Zeagle Ranger LTD BCD size MD Great condition for sale
    $400USD plus shipping $30USD to North America
    The Ranger was the first BC to combine high quality heavy duty construction, weight integration, and rear flotation. It's introduction created a new category of buoyancy systems, and it is without doubt the most imitated BC in history! But it's the Ranger's incredible versatility that keeps knowledgeable divers recommending it year after year. Zeagle's modular construction allows the Ranger to transition between tropical travel diving, rugged cold water diving in wet or dry suits, single or twin cylinders, and even (with optional bladder assemblies having up to 2 X 85-LB lift and easily mounted backplates) technical diving!
    No other BC has such a loyal following and such a solid reputation for functionality, comfort, and durability. The Ranger Limited has all the features of the legendary Ranger BC, PLUS many innovative additions that make it even more functional and versatile!
    If you are a diver who wants a rugged recreational buoyancy system, but also want one that can adapt and change to meet different diving needs, the Ranger is a system you won't outgrow.
    • 44-LB lift capacity Ballistic bladder (standard, other capacities available as options)
    • 30-lb capacity Ripcord® weight system
    • 20-LB capacity rear trim weight system
    • PFS Modular Sizing
    • Heavily reinforced 1050 denier Ballistic nylon construction
    • 11" grommets for mounting twin cylinders
    • Two Zippered utility pockets at sides
    • Adjustable elastic waist panels
    • 4 Stainless angled D-rings on shoulders (two adjustable)
    • 2 Stainless D-rings on vest
    • Adjustable Sternum Strap
    • Single or twin tank capability. •
    Added features of the Ranger LTD.
    • A lumbar pad is permanently mounted in the rear of the vest section.
    • The Removable rear weight system (8051Z) is included.
    • A pair of 18lb capacity shot pouches are included.
    • An extra set of vertically mounted D-rings are positioned ideally for mounting extra cylinders or accessories.
    • Two additional 1.5" D-rings are located at the bottom rear of the vest.
    • The Tank Bands are designed so they can be lengthened to hold twin cylinder sets.
    • A Zipper attachment system mounted inside each wing of the bladder allows for the attachment of a variety of carriers and accessories, including Pony bottle carriers, Spare Air carriers, extra pockets, and grommet panels.
    • Accessories can be easily changed for different diving requirements. Check out some of the currently available accessory attachments and other features below!
    Expandable zippered utility pocket on front of vest
    http://www.pbase.com/yahsemtough/image/76871213/medium/jpg
    Vest
    Measure waist size
    SM 25"-35"
    MD 33"-41"
    LG 37"-45"
    Measure shoulder to waist
    SM 14"-18"
    MD 18"-22"
    LG 22"-26"
    $400USD plus shipping $30USD to North America (Yes, Canadian flag is removable)
    PM me please
    Edited by yahsemtough
