Nikkor 50mm 1.8D underwater
Started by aczyzyk ·
  1. Why? I flooded my macro lens and I was left with 10.5 only. I wanted to shoot some smaller stuff too, I tried this combination: Nikkor 50mm 1.8D with +4 diopter behind ikelite 6" tiny fish eye port.
    Here are some samples: 50mm 1.8D - test
    Unfortunately I only tried that on one night dive with strong current, so I did not manage to test how close it could actually focus. I liked the sharpness of this combination. Not great photos but they prove it works ;)
    Anyway I will give it some more testing. I'm thinking about using it in a minimalistic travel kit:
    1) Ikelite with 6" FE port - the port is tiny and the whole housing with port on it fits in my Lowepro backpack.
    2) 10.5mm, 16mm and 50mm - all go behind the same port
    3) 50mm is not a true macro but seems ok for anemone fish etc.
    What do you think?
  2. It's looks like a good alternative but I think I'll continue to prefers the 60 micro in regular situations, its very close in size and its a real 1:1 macro, of course you need the extra port but its worth it.
  3. Why not a flat port? You'd get better magnification...
    I'm interested in seeing more shots. Almost everyone has one of these in their camera bag as it's only $100,. I think it's true value may be for available light shots using it's faster speed.
    Please post more shots when you get them. I might try a dive with mine with a diopter on it. But as Arnon has stated the 60mm macro is a much better idea UW overall, almost all the shots you posted would of been better closer up.
    Jack
    Edited by JackConnick
  4. It seems to work well. These shots are good.
    This would be a good way to get a measure of macro on the cheap--esp for fish portraits. To take this up a notch you could try it with a flat port and a 3/4T diopter. That would allow you to get closer, get the added magnification we are used to with a flat port, and improve the sharpness a bit.
    Good idea and thanks for posting. The 50mm at $90 is a smoking deal!
