Ignorant question - faxing Indonesia
Started by scorpio_fish ·
  1. I'm a little helpless today. So, I want to fax something to Indonesia from the US. I've been given a fax number of 11 digits beginning with ++62____. What do I punch in before hitting the 6, 2, etc.?
  2. I think you hit 011 (from the states) then the 62 (the country code probably).
  3. Don't think anything is in front . You just use the 11 digits you have. also depending on who/where you are faxing don't be suprised if it doesn't get thru at first.
    Just checked an old fax to Bali-use the 011 code first.
    Edited by mtnman
  4. 011 is the correct numbers to dial first
    TErry
  5. Thanks all.
