Wanted Ikelite 5505.58 Flat (macro) Port
Started by Synthesizer Patel ·
  1. I'm guessing that there's not much chance getting hold of a used one as these seem to be the most useful of the macro ports for canon shooters like me and people tend to hang on to them - but if someone out there wants to help out a financially challenged student I'd appreciate it.
    Edited by Synthesizer Patel
  2. I'm guessing that there's not much chance getting hold of a used one as these seem to be the most useful of the macro ports and people tend to hang on to them - but if someone out there wants to help out a financially challenged student I'd appreciate it.
    Hope it's ok to ask a question instead ...
    Which macro lense does this port fits ? Can it be use with the Nikon 105VR ?
    Thanks!
  3. Hope it's ok to ask a question instead ...
    Thanks!
    feel free
    although this is the port you would use for a sigma 105mm when shooting with a canon dslr, apparently you need a 5505.46 for the Nikon 105VR
    here's a link to the port compatibility chart on the ikelite website - its not completely comprehensive as there are other lenses not listed that will work with certain ports - but its a very useful reference nonetheless..
    http://www.ikelite.com/web_pages/2port_nikon.html
  4. feel free
    Thanks ! I wonder what is the real difference between 5505.46 & 5505.58 ? Is it the diameter or the length or both ? May be I need to ask Ikelite then. Thanks!
  5. Hi- I have an ikelite 5505.58 flat port i got as part of a package. It is brand new and has the neoprene cover for it. I would like $80usd plus shipping charges. My email is dweeks@telusplanet.net. I can send pictures if you would like.
    FLAT PORTS
    For standard, macro and telephoto lenses.
    Due to refraction flat ports reduce the angle-of-coverage of a lens and at the same time enlarge the image. This makes the flat port ideal when using standard, macro or zoom lenses to shoot small subjects. Note that if a port is long enough to accommodate the full length of a 1:1 macro lens, the lens may vignette when used at infinity. If access to the lens' full range is desired, then select a dome port instead.
    5505.58 Lens less than 6.1" (15.5cm) ... $150
  6. Bumpity bump :rolleyes:
