Sea&Sea TTL converter
Started by fras ·
  1. Any experiences?
    I have a Heinrichs converter but have a lot of problems with it.
    I read other threads but not found all the answer that I need.
    How performs? Results are predectible and consistent?
    Works well with Subal housing (D2oo)?
    Any experience with subtronics (minis) '
  2. my setup.
    Subal D200, S&S TTL, dual Inon Z-240
    the exposure has been good. very consistent.
    Just got back from the Philippines for two wks.
    great for macro.
  3. my setup.
    great for macro.
    Thanks Larry,
    any experiences with subtronics?
  4. I just got the sea and sea converter for my d2x/ inon 240s. Ive only tested above water so far but topside system works well. Ryan at reef photo in fl. was very helpful
  5. I *think* the Sea & Sea converter is in fact a packaged Heinrich's converter, so they are one and the same.
    Can anyone confirm?
  6. My understanding is the Sea & Sea converter is in fact a packaged Heinrich's converterbut with a larger battery and the adjustment is external to the housing.
    We're just getting our's dialed in in pool practice. Had to adjust camera flash compensation to -1.7 to get the converters range in correct exposure.
  7. Hi Okuma,
    I too am trying to get my D70S with Nexus housing and the S&S i-TTL 'gizmo' dialled in.
    How do you judge the exposure to be "correct exposure"? Is there a chart or are you using light meters or what? Is "correct exposure" subjective?? I am at a total loss as to where to start with this 'dialing in' process... :)
    Thanks for taking the time,
    Bruce
  8. Hi Okuma,
    Bruce
    Hello Bruce!
    The histogram is the "truth" :) .
    I think there are two ways of working:
    - For RAW pictures that are going to be RAW post processed etc... you should try to obtain a histogram as close to the right without burnt areas (or only burnt areas such as the sun which is always burnt). Jpges obtained this way look ugly but their RAWs have a lot info and a higher signal/noise ratio.
    - For JPG pics that will be more or less used straight out of the camera you should try to find your personal taste and kind of pictures histogram (usually centered or a little bit to the left) and learn to identify the image you get in your camera screen with the one you get at home in your computer.
