Partner whip coral shrimp
Started by andrew73 ·
  1. Any C&C on the shot would be much appreciated!
    I've cropped and edited it some. Also, is there any way I can 'watermark' it on Photoshop?
    Thanks!
    Cheers! :)
    Edited by andrew73
  2. Hi Andrew,
    Your processing of the photo looks good. The only improvement I can see would be to shoot it from an angle so that you can see both eyes.
    The color looks good but you may try playing w/ the red curve to pump it up a bit.
    To watermark the photo just use the Text tool and set the Opacity to whatever looks good.
  3. Hi James,
    Many thanks for the tips. Was a bit of a challenge taking the shot initiall as the whip was perpendicular to the wall and I didn't have much of a surface to 'plant' myself while taking the shot, apart from the slight current! :rolleyes: Am glad the little fella wasn't keen on moving about too much! What's the chance of dislodging the whip if I adjust it's alignment to get the frontal shot? I understand these sea whips are quite hardy, yes?
    Again, much appreciation for the help.
    Cheerio!
    Edited by andrew73
  4. Hi Andrew
    To watermark the shot in photoshop
    select the black forground and white background in the toolbox (left of screen)
    select the text tool and type in your watermark.
    position the text by dragging it to where you want it.
    Left click the text layer box (bottom right of screen) this will isolate the text layer.
    Go to Filter at the top and scroll down to Stylize then right to emboss.
    Click yes to rasterize image and set the emboss peramiters, click OK
    Just above the layer box is an options box (its really small) showing normal,
    Left click will open options and the best one is overlay for watermarks but have a play to see which one suits the image the best.
    I hope this makes sense
    Good luck :rolleyes:
    Nige
  5. Hi Nige,
    Didn't get past the black foreground and white background! :rolleyes: I can't find a 'text tool'! Is the 'Type tool' the same thing?
    I've only managed to type text where I wanted to put the mark and after that, even with right-click, I can't get the filter you mention.
    Sorry! Real bummer this!
  6. Andrew,
    Sorry I wasn't that clear, probably the bottle of Bushmills 10 year old malt had more of an influance than I expected. :rolleyes:
    Try this
    http://www.grafx-design.com/18photo.php
    It explains it better than a drunk old computor technophobe on Wetpixel's forums.
    If you have no joy try a google search for "Photoshop Watermark Tutorial"
    Theres absolutely Gazillions of photoshop sites out there
    Again good luck
    Nige
  7. Hi Nige,
    Thanks again. Perhaps if I had a few shots of the Bushmills, I'd be able to figure out what you were trying to tell me! :rolleyes:
    Have managed to get it done! Cheers!!
    Edited by andrew73
  8. Andrew
    Life looks sooooo different through whiskey goggles :rolleyes:
    A bit like a 70m dive in the English Channel on air ..... Wierd and Scarey but you dont care.
    I'm glad you've got it sorted.
    Take Care, Dive Safe.
    Nige
