Hi, I’m new to the forum (at least posting) and was wondering about a few technical questions about macro photography. I have the 30d, with ds125 strobes.
1. I have the EFS 60 mm macro, and I have a very hard time hitting focus on a regular basis notwithstanding the varying aperture settings. I have tried AF One Shot and after locking focus, obviously the slightest distance change ruins the sharp focus. The AF Servo seems to work a little better at tracking moving objects but seems slow to react. I am curious as to what others are doing. I have tried focusing lights, which seem to help some, but the LCD ones with diffusers don’t seem to be strong enough. Likewise the modeling lights don’t seem to work well. The zenon ones leave spots. I was wondering, people who have both the 100 and the 60mm, if the 100mm has the same sluggish focus problems (slow, low contrast, low light) as the 60, because it has the limiter (which I don’t know how far out, it locks).
2. Secondly, if theoretically, we were shooting the same object with both lenses, we would have to move the 100mm back away from the target to get the same image size on the sensor. After doing this to achieve the exact same size on sensor, would the depth of field be the same using the same aperture, or would the 100 have a larger one. Similarly, same scenario, we move both lenses back away from the target (say 1 inch to make the math easy) the same distance without adjusting focus, would the 60mm be more out of focus because the ratio of the change to the target distance would be greater? EG:100mm lens is 24 inches from target, 60 mm is 14 inches from target (or whatever it is to make the image size the same on sensor). 100 lens would only change 1/24 of the distance or about 4%. The 60mm has moved 1/14 of the distance or about 7%. The question is, is the slight amount of movement that actually occurs underwater while taking the photo, more critical with the 60 mm, as one has to get almost twice as close to get the same image size.
3. With all lenses, there is obviously a drop off in resolution (MTF charts) and contrast at around f16 and smaller; the question would be when is too small of an aperture to increase DOF, really creating diminishing returns, as far a picture quality (image sharpness vs DOF).
4. Would there be any disadvantage using the same port for both of the lenses (so I don’t have to schlep so much crap around) even though there would be a couple of inches of air in front of the 60mm in the port. Would it throw off the focus?
I have a lot more questions, but don’t want to get overwhelmed all at once. Thanks for your feedback. Phil
