D 70 settings
Started by joeyfishes ·
D 70 settings
  1. Trying to think out my setting for starting out with the 60 mm D70 and the SB 105. Let me know if I am thinking right
    shutter speed 120 (2x focal length of lens)
    aperture( using guide # of strobe)
    3 ft f11- f8
    2 ft f f 11-f16
    1 ft and under f 16 -22
    color balance -Flash- automatic or cloudy or Custom -any idea what the color temp of the SB 105 is?
    Do you ever hand hold the strobe to bracket exposure with a housing?Or is the housing to heavy?
    Exposure meter -Matrix metering center weighted or spot ?
    Auto focus dynamic area
    auto focus/exposure lock on ( i guess the exposure lock wont matter as I am shooting in manual)
    image quality large jpeg or raw and jpeg
    am I thinking right
  2. Trying to think out my setting for starting out with the 60 mm D70 and the SB 105. Let me know if I am thinking right
    3 ft f11- f8
    2 ft f f 11-f16
    That values works fine to me also
    I use auto, can be changed later since I shoot RAW
    I like spot or centric
    Same for me
    I shoot always RAW, If from some reason I need fast results for review I use raw and basic jpeg
    am I thinking right
  3. Thanks!!!!!
  4. Thanks!!!!!
    One suggestion...
    set your display to show a 3-color histogram after each shot, that way you can instantly see if you need to adjust your aperture...
    auto-white balance works well for me
    hope this helps,
    Scott
  5. set your display to show a 3-color histogram after each shot, that way you can instantly see if you need to adjust your aperture...
    Unfortunately, the D70 doesn't have a 3-color histogram (only one), but I do agree that the histogram is helpful. I always have the review set on either histogram or highlights to quickly check exposure.
    I shot RAW+jpeg, and normally auto white-balance. Metering is normally center-weighted. Auto focus is dynamic area and continuous. I know some people recommend single auto focus, but I prefer continuous, as you can just use the AF/AE lock when needed.
  6. Unfortunately, the D70 doesn't have a 3-color histogram (only one), but I do agree that the histogram is helpful. I always have the review set on either histogram or highlights to quickly check exposure.
    Thanks very much !!!!
  7. I occasionally hand hold my strobes but not to bracket. I have an Ikelite removable segment so that I can backlight a scene or get some strobe position I'm not able to get while attached.
    The housing wile underwater isn't too heavy to do this but I'm glad I have strobe arms for most of my shooting.
  8. I occasionally hand hold my strobes but not to bracket. I have an Ikelite removable segment so that I can backlight a scene or get some strobe position I'm not able to get while attached.
