Resolution of framegrabs from Sony HDR-HC7
Started by Keith1ocean ·
  1. I've been using TRV900's as a tool to shoot video along reef transects since 1998 as a component of various reef monitoring projects. Very satisfied with the cameras and housing (Amphibico Navigator) but we're looking to upgrade to HDV to improve resolution of imagery, to allow more detailed analyses of species composition in video frames. Digital stills not an option due to in-water bottom time constraints - you can cover alot more bottom with video than a still camera in a dive). We currently take the raw video data shot with progressive scan and do individual frame grabs using iMovie on an Apple G4 with a dual processor, ending up with 640 by 480 jpegs (may end up with hundreds of frames per transect). Then we review individual frames with image analysis software. What would be the positives (and negatives) of going to an HDR-HC7? Or any other HDV model?
  2. Well take a look yourself.
    Well here is a 1.1 HDV screen grab.
    Straight from the HDV timeline with one single click using EDIUS :) .
    TRV900 does not do true progressive scan. It's like 15 fps and it's still not true progressive.
    Edited by wagsy
  3. sorry I don't know yet how to do a framegrab from any of the NLE's... But here's frame captured directly from the HC7 camera to the memorystick.
    edit: forgot to mention that the capture is from the playback of the HDV footage on tape.
    Edited by pakman
  4. Keith: Its great that you are using this technology to inventory reefs. I think with HD you will find that frame grabs allow greater resolution in terms of species identification and composition. You should also be able to detect dieoffs or other problems at an earlier stage...that is in smaller patches than with standard video.
    The downside, and with the price of storage now being pretty cheap I don't think its a big downside, is that you'll need more hard drive storage space, and possibly faster computers to process the footage. IMovie HD should be adequate for what you want to do, so I don't think you'll be looking at expensive software upgrades.
    The TRV900 is very good in low light; if you shoot in low light conditions frequently you should definately check the HC7 capability before committing, but if you are filming in clear water and good lighting it is probably not a concern. You may wish to check the low-lux ratings of other HD camcorders though. I have been watching Canon's HV20 closely to see which housing manufacturers will make an underwater housing for it. So far only Ikelite has announced a housing. JMHO.
    Edited by Hawkfish
