Take your CP5000 UW - what you will need
Started by Krash ·
  1. I am posting this for newbies like myself. I gathered info from this forum and a local Ikelite dealer. Thanks for the input.
    (retail prices)
    CP5000 Housing - $950
    CP5000 Strobe Kit** - $1015
    Arm Mount - $30
    Dome Port - $150
    Nikon 19mm WA lense - $175
    Nikon lense adaptor - $15
    Total - $2335
    **Strobe kit includes:
    DS125 Strobe
    Charger
    Quick Grip II Arm
    Sync Cord
    Hard Case
  2. I can't resist jumping in on this one...hehe
    Here would be a "bare bones" estimate:
    Sea and Sea YS90DX and Sync cord: $500
    Arm Mount - $30
    ULCS 2 Joint arm system: $180
    Wheeled Igloo Cooler as a case: $40
    (The wideangle lens is NICE, but not essential)
    Total - $1700
    You could substitute the YS90 strobe with a DS50 or a Substrobe50 if that's your preference and save $100 more.
  3. The Ikelite dealer I am working with made it sound like I had choices for domeports to work with the Nikon 19mmWA lense. Is this true? If so, what are the differences with the ports that will work?
  4. I think that this housing will have two ports. The flat port which accepts add-on lenses, and the dome port which is specifically designed for the Nikon 19mm lens.
    HTH
  5. The DS50 SubStrobe package (same intensity and coverage as YS90) is $500 including arm system, sensor, everything you need. The Coolpix 5000 has a wider angle lens than the Olympus and housing accepts external wide angle lenses from Sea & Sea or Inon. Optional port with dome will be available to accept the Nikon WC-E68 19mm conversion lens.
    Coolpix Housing information
    ike
    [Edited on 4-20-2002 by ike]
